How do I transfer a toolbar from one computer to another?
rataylor
rataylor
I created a toolbar that I want to use on a different computer. How do I transfer a toolbar from one computer to another? The customization file is in the CUI dialog box. How do you turn it on such that it is always there when I open a drawing? Toolbar creation and utilization was really easy with 2004 and I struggle with the "new and improved" toolbar creation and using procedures.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @rataylor,
Thank you for posting. This Autodesk Knowledge Network (AKN) discussed transferring toolbars
On your second question, I think you mean you would like the CUI open whenever you open a drawing. I think the only way to do that is to set up a script that will run whenever you open a drawing. The Visual LISP, AutoLISP and General Customization members will be able to help with this.
Please let me know if that helped.
You can use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
rataylor
No, I just want my toolbar to come on. I just type CUI on the command line if want to open the CUI dialog box.
rataylor
BTW... the "transferring toolbars" link in your reply is dead. Later, rt.
dmfrazier
Hello again, @rataylor ,
Turning on a toolbar constitutes a change to your current Workspace. Assuming the toolbar is defined in a CUI that is currently loaded in your profile, you can do this either in the CUI editor (as I described in your other post), or you can do this within the drawing editor interface, by right-clicking on a blank area where toolbars might normally be docked, selecting the name of the CUI (menu) that contains the toolbar, and then selecting the name of the toolbar you want turned on. You can then re-position the toolbar if necessary.
If any of this is difficult for you to follow, then I strongly suggest you seek out a more direct "training" source that can provide you the one-on-one attention you seem to need, which this type of forum is not really well-suited for.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @rataylor,
Thank you for letting me know about the link. I am not sure why it appeared dead for you, I was able to open it after posting. I updated the link so it should be good now.
Thank you also for the clarification. Toolbars can be called up from the TOOLBARS command by name. You can also access them from the Tools tab in the Menubar when it is active (set to 1).
Please let us know if that helped.
All the best,
Cheryl Buck
