AutoCAD Forum
How do I set origin point for attach xref easily
9 REPLIES 9
Message 1 of 10
edenbU7RGS
851 Views, 9 Replies
edenbU7RGS
I want to pick a point in my drawing so when ill insert it to another drawing as an Xref it will be from that point i picked.
now when im insert my drawing is far away
Labels (3)
9 REPLIES 9
Message 2 of 10
apjones
in reply to: edenbU7RGS
apjones
Use the "BASE" Command in the file you want to reference into the other file and select a new "origin" reference point..
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Pete
Message 3 of 10
Kent1Cooper
Kent1Cooper
The BASE command / INSBASE System Variable [read about them in Help].
Kent Cooper, AIA
Kent Cooper, AIA
Message 4 of 10
edenbU7RGS
edenbU7RGS
I want to set this intersection of those 2 grids as a basepoint.
the big numbers next to the command shouldn't be 0,0,0?
Message 5 of 10
pendean
pendean
Community Legend
Community Legend
Why would you assume that please? Are you confident UCSICON command set to ORIGIN for example?
Message 6 of 10
edenbU7RGS
in reply to: pendean
edenbU7RGS
in that case i dont care about the coordinate. just to pick the point that i will insert it to another drawing.
Message 7 of 10
Kent1Cooper
Kent1Cooper
That's exactly what the BASE command is for.
Kent Cooper, AIA
Kent Cooper, AIA
Message 8 of 10
edenbU7RGS
in reply to: Kent1Cooper
edenbU7RGS
ok so i opened new drawing file and draw two lines and set the insert section of them as a base point.
then i opened one more new drawing file and attached the drawing with the two lines and insert it on the 0,0,0 insertion point and it worked perfect! but with the drawing file i mentioned in the first post here it didnt work and i trying to understand why. do you have an idea? i've attached the etransmit file.
Message 9 of 10
Kent1Cooper
Kent1Cooper
I used BASE to define a base point in your sample drawing, and Inserted that into another drawing with exactly the expected result -- the point I had specified was the insertion base point used to Insert it.
Could your problem have something to do with the fact that things are drawn over 70 million drawing units away from the 0,0 origin?  [Since your drawing unit appears to be a centimeter, that's over 700 kilometers!  Or, it's over 1.5 times the entire east-west length of my home state of Pennsylvania.]  Does it help if you Move everything closer to the origin?
EDIT:  By the way, having things so far from the origin can cause other kinds of errors, too, because AutoCAD can only keep track of a certain number of significant figures for numerical values.  So you should Move things closer to the origin even if it doesn't solve this problem.
Kent Cooper, AIA
Kent Cooper, AIA
Message 10 of 10
pendean
pendean
Community Legend
Community Legend
@edenbU7RGS wrote:
...i've attached the etransmit file.
Thanks for sharing your file: this is the "origin point" in the DWG in your ZIP file
Where do you actually want your "origin point" to be please? I assume somewhere near here
Let us know.
Let us know.
AutoCAD Inside the Factory
