How do I hide the Specify point, distance, and angle?
Message 1 of 11
When I select or specify a point, the Specify point, distance, and angle are in the way of my view. How do I hide them?
See Attached screen pic.
Replies (10)
Message 2 of 11
imadHabash
press F12 .
Imad Habash
Message 3 of 11
Thank you for your response.
I see that it works to hide if you continue to hold down the F12.
Is there a setting that hides them without holding down a button?
Message 4 of 11
GrantsPirate
If you want to know how to control what is displayed when Dynmode is on right click on the DYNMODE icon, pick settings, and explore.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 11
john.vellek
Hi @Anonymous,
From your attached image it appears that the DYNMODE Dynamic Input fields are getting in your way. F12 is the temporary override.  Here is an article that describes the four values you might use to improve the way this feature works with your drawing practices.
John Vellek
Message 6 of 11
imadHabash
NO.. pressing F12 will toggle you off and on.with no command is active press F12.
Imad Habash
Message 7 of 11
Can't for the life of me find the Dynmode settings.
Message 8 of 11
Only works when you hold it down. Doesn't seem to toggle for me. Neither during a command or not.
Message 9 of 11
Patchy
Try hold down CTRL key then the F12 key
Message 10 of 11
john.vellek
Hi @Anonymous,
Can you not type DYNMODE at the command line? Does it return an error?
John Vellek
Message 11 of 11
Solution:
Simply reset to default after downloading 2017.1 update.
Fixed all my problems.
