I have received a drawing from a contractor, when opening the drawing, it says missing shx files. Is there a way to tell the contractor the name of the missing shx files or do I just need to request all of the shx files they used? Also, are missing shx files specifying for fonts, or do shx files also mean linetypes?
Solved by Alfred.NESWADBA. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
You can tell them to use ETRANSMIT to send you the drawing, which should include all the fonts used along with it.
.SHX fonts don't "mean" linetypes, but their presence or absence affects them -- if a linetype has any embedded text element(s), you will need to have the font file(s) used in the Style(s) called for in the text element(s).
When you get the message about missing SHX you can answer the dialog with "specify a replacement ...." and there you get each of the missing SHX-files shown (while you can select any other SHX-file to define the replacement and go through each file then)
- alfred -
