How do I display a specific attribute attached to different blocks
andrew_wheaton
Message 1 of 13
andrew_wheaton
I have a file of hundreds of Pay and Display parking machines.
Helpfully, they are all named differently, but represent the same thing. I want to display the machine number, list as "MACHINE" within a ream of attributes attached to each block.
Is there a quick command or routine I can use, to show that one attribute as a piece of text?
Would save our junior technician hours of work, and the project too!
Replies (12)
Message 2 of 13
jtohill
I use a data extraction under tables and chose the block name that has the attribute you want the information from.
Message 3 of 13
andrew_wheaton
I need to show the atribute as a piece of text, not a table.
Message 4 of 13
jtohill
If the attribute just needs the text to be visible you can modify the block, select the attribute and make it not invisible and it will show.
Message 5 of 13
andrew_wheaton
I have 450+ blocks. Is there a quick way rather than doing this one by one?
Message 6 of 13
andrew_wheaton
Also each block is named the same, just with a sequential number at the end. So its not just the cast of editing the block and turning showing the attribute.
Message 7 of 13
jtohill
you only have to do it once and all the blocks will have it showing. If you upload the block here it would help.
Message 8 of 13
andrew_wheaton
File attached
@jtohill
Message 9 of 13
jtohill
These are interesting blocks the attributes seem to be only attached to the points not within the block itself. I can extract the attributes in a table but the blocks do not have attributes within them and the drawing states that it was not autocad that  created the drawing.
Message 10 of 13
jtohill
use a multi leader to tag the blocks separately and insert field choosing the machine attribute.
Message 11 of 13
andrew_wheaton
I know, they were supplied by a client, seems like a GIS convertion. Not ideal.
Message 12 of 13
jtohill
here is what i mean.
Message 13 of 13
andrew_wheaton
@jtohill
The way I did it was to Data Extract the X and Y’s and Machine names from the original file. I then created the attached spreadsheet, amended from a setting out point tasks I did similarly for Southall. Once the source block is inserted, you then just copy and paste the final column into AutoCAD. then I scaled the block from its insertion point to the correct size.
