How do I dimension identical viewports with same scale
Message 1 of 8
I have several identical viewports, with the same view and scale.
How do I dimension each viewport individually in model space using one layer?
I don't want multiple layers to freeze and I don't want to dimension in paper space.
Thank you!
Replies (7)
Message 2 of 8
natasha.l
Hello @Anonymous,
You can apply dimensions in paperspace or modelspace. I recommend using these steps:
  1. Create your "dimension" layer
  2. Use the Dimensions Styles Manager to create "New" Annotative dimensions style
  3. Select your preferences
  4. "Apply" & "Set Current"
[video]
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 8
imadHabash
you can start putting dimensions in your Model layout , is there any thing preventing you from that ?    we need to see your CAD drawing to check your viewports limits and give you a direct and proper solution .
Imad Habash
Message 4 of 8
Moshe-A
@Anonymous  hi,
What do you mean identical viewports?  they have the same exact view?
the only way i know to distinguish between identical viewports is layers thus you will need to define some layers for dimensions.
moshe
Message 5 of 8
Moshe-A
@natasha.l  hi,
Sent you a private message, please take a look
thanks
moshe
Message 6 of 8
Alfred.NESWADBA
Not sure if that is really the best solution, you might create for each viewport a different scale like 1:1A, 1:1B, 1:1C
Now assigning an annotation scale 1:1A to the dimensions you want to see in the first viewport, 1:1B for the second viewport ...
So the scale 1:1 can be the same for all these viewports, the layers can stay the same, but if you are happy administrating these annotative scales, I would be scared getting such a drawing if I would have to work/modify it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 7 of 8
Yes, they have the same view.
Unfortunately I have too many viewports to create a layer for each one.
Message 8 of 8
Yes, this might work. But I would be scared too.
I guess dimensioning in paper space is my only option.
thanks
