AutoCAD Forum
How do I change Text Style on multiple blocks?
2 REPLIES 2
joe_kohli
107 Views, 2 Replies
I have multiple blocks with attributed text within them. The font style needs to be change to be readable. I have hundreds of the blocks (tags) that are not in readable text format and need to get them changed in a relatively rapid manner. How should I approach this? I've tried GATTE but that only changes the text of the block, not style. See the block I attached.
2 REPLIES 2
pendean
in reply to: joe_kohli
STYLE command: your blocks are all using ROMANS style name, with ROMANS shx font. Pick something else for a quick fix while you want for tips on how to repair your entire library of blocks.
REGENALL after you make the font change.
paullimapa
Could you do a screenshot showing the unreadable block attribute and share that here
Paul Li
IT Specialist
@The Office
Technology Administrators
