How copy Block from drawing to another?
Leonardo_Czuy
Leonardo_Czuy
I have two drawing with block have same name but have diferences, i wanna copy block from drawing 1 to drawing 2, without need deleted block e and purge in drawing 2, i wanna copy, past and in drawing 2 will updated automaticaly.
Thanks everyone for any help.
Kent1Cooper
In drawing 2, go into the Design Center [ADC command, or Ctrl+2], navigate to drawing 1 and its Block section, and right-click on that Block.  You will be given the choice of whether to:  A. Insert one [in which case it will use the definition already in drawing 2], or  B. update the Block's definition in drawing 2 to match that in drawing 1 [without Inserting another], or  C. update the definition and Insert another one.
Kent Cooper, AIA
VincentSheehan
You can use Design Center. Open drawing 1. select drawing 2 with the updated block. Right Click and Redefine.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
