How come I cannot see my model drawing in the layout platform??
toyotahideaki
toyotahideaki
There is odd something  that is cannot see the model drawing in the layout platform and I already checked all relevant factors including scale , layers , page setup setting , Draw order set to the back fuction but still not work . One more thing I found the originally drawing which I need to trace my blue print . It was appeared in layout platform , also the same size same setting with my blue print. Anyone know what happen? thx
Accepted solutions (3)
imadHabash
would you please pick inside the VP and check your layer status , scroll to right direction till you see VP Freeze tab and see if it's freezed or not .
Imad Habash
toyotahideaki
Cool ! It can work now ... but I haven't noticed this fuction . thank you !
BTW , what means "VP"? and I haven't closed this fuction up to now so I had no ideas before ...
imadHabash
glad that your issue is resolved . 🙂
>> what means "VP"? >>
VP = Viewport .
Imad Habash
toyotahideaki
excuse me sir , I found all VP was switched on but just can see the exterior walls line , doors and windows blocks couldn't shown ... What is this mean ?? thxred market6.png
imadHabash
>> ..... d windows blocks couldn't shown ... What is this mean ?? <<
from your attached image i notice that you're out of VP ... please pick inside your vp ( vp active ) then show your layer dialog to notice that there is still some VP layers are still freezed .
All the best ...
Imad Habash
cadffm
Thats the layer (vp)properties of your current Layout tab - works for objects in Paperspace.
You need to check vp properties for your viewport.
Doubleclick into your viewport, statubar information switched from paper to model.
NOW look into Layer palette.
End dont forget to go back to paperspace after this.
Sebastian
