AutoCAD Forum
How can two different size of text be actually the same size?
10 REPLIES 10
Message 1 of 11
john.p.addy
723 Views, 10 Replies
john.p.addy
I'm having a issue here.  I have talked to my co-worker also and he did not even notice what was wrong.
Here is the picture I sent him but I high lighted what I was hoping he would noticed.
How can two different size of text be actually the same size.
[ The subject line of this post has been edited for clarity by @handjonathan Original: I'm confused here.]
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Thank you,
John Addy
10 REPLIES 10
Message 2 of 11
pendean
in reply to: john.p.addy
pendean
Community Legend
Community Legend
MTEXT text allow for manual overrides: it's a feature, just like color etc.
PROPERTIES is showing you the default settings: it never shows overrides, and in this instance, it cannot even change them back.
It's been like that in AutoCAD since MTEXT showed up, 30+years now? Possibly longer.
Message 3 of 11
john.p.addy
in reply to: pendean
john.p.addy
OK thank you,  I never knew that and have worked on AutoCAD since Acad 10
Thank you,
John Addy
Thank you,
John Addy
Message 4 of 11
Kent1Cooper
Kent1Cooper
If it's a height difference from Mtext-content-internal formatting, you can see the current height anywhere in it [and compare that to the Mtext object's nominal height]:  get into the Mtext editor, pick in the part you want to know about, and the ribbon will show you:
Kent Cooper, AIA
Kent Cooper, AIA
Message 5 of 11
cadffm
cadffm
Check the property CONTENTS to see the real MText (contents) value, incl. all internal format overrides.
Sebastian
Sebastian
Message 6 of 11
CalamityJane32
and if you don't' want them to be overridden, there is a handy lisp called STRIPMTEXT that set everything back to its default values.
Message 7 of 11
illusionistNUGXG
It seems, that it doesn't make sense to be able to override the height of the MText at first look.
But it can have various text-heights within the same MText. Now you can scale the complete MText with the "global" text-height.
Unfortunately...it can get quite messy, if you get careless. (The main text-height should match the "global" text-height of the MText)
Message 8 of 11
RobDraw
in reply to: illusionistNUGXG
RobDraw
What is "global" text height and how do you use scale to match it?
Rob
Rob
Message 9 of 11
illusionistNUGXG
in reply to: RobDraw
illusionistNUGXG
@RobDraw  schrieb:
What is "global" text height (...)?
Uhm...with "global" text height i meant the set height of the MText in the PROPERTIES.
@RobDraw  schrieb:
(...) and how do you use scale to match it?
Scaling to match it doesn't work.
What i tried (and failed) to say was:
With different text-heights in one MText - At first make sure that the main used text is set to the same text-height value as the MText height in the properties.
As example: I have a MText with a height of 10 and most of the text inside is also set to the height of 10. To highlight a part of the text, it is set (overwritten) to a height of 15. It has 1,5 the size of the main text.
If i now change the height of the MText in the properties to 18 the main text will be 18 and the highlighted part "scaled" to 27. It will keep the 1 : 1,5 ratio between these two.
Message 10 of 11
RobDraw
in reply to: CalamityJane32
RobDraw
There is also the "Remove Formatting" option in the MText editor.
Highlight the text and it's in the right click menu.
Rob
Rob
Message 11 of 11
illusionistNUGXG
illusionistNUGXG
Oh, nice...didn' know that one.
I'll add it into my workflow.
AutoCAD Inside the Factory
