I'm knew to autocad and was wondering if anyone could help me find out how to hollow out a simpe 3d object (cube, cylinder)? (I'm using the mac version 2015)
Solved by nestly2. Go to Solution.
Solved by leothebuilder. Go to Solution.
I think the "Shell" command takes you to the operating system.
If you need to hollow out a 3d object, create a 3d object of the hollowed out portion, and use the "Subtract" command.
The Subtract command will allow you to subtract one 3d object from another 3d object.
I'm prettys sure Shell was one of the original operations included with the introduction of SOLIDEDIT command in 2000
or
you can use Autodesk product - Screencast Recorder which is free.
Can the screencast recorder create a GIF image? I wasnt aware it could do that.
As you said Screencast Recorded is free on the other hand it is Autodesk product, so can I use this software to record any other non-Autodesk software's screen recording?
