How can I do this in 3D?
Jorge.Sanchez
Message 1 of 14
Jorge.Sanchez
Hi, I was curious if anyone knew how to create this extrusion in 3D. I have a profile and a series of lines that are not in the same plane and change direction in all three axis and other factors. If anyone can help it would be greatly appreciated.
Replies (13)
Message 2 of 14
Jorge.Sanchez
Message 3 of 14
imadHabash
Arcs , Lines and Splines alone and separately can not be extruded . we need to know what is your final shape to give you direct answers regarding your issuw ? 🙂
Imad Habash
Message 4 of 14
Jorge.Sanchez
Thanks for your prompt reply Imad Habash
The final shape is the profile you see on the image at the bottom right and it needs to follow that path as if it were extruded along the path. Yes, arcs, lines, are all separated but the profile needs to follow this path. Its basically a wall molding that follows an arc and walls that go in and out.
Message 5 of 14
Jorge.Sanchez
Its a ceiling molding that goes in and out as the wall and ceiling arc. See image. Attached is .dwg file
Message 6 of 14
Alfred.NESWADBA
use command _SPLINEDIT to connect all path objects together to one spline-object.
Then start command _EXTRUDE, select your contour-object, then option _PATH and now select the new spline.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 7 of 14
john.vellek
Hi  @Jorge.Sanchez
I used Extract Edges to get the path for my sweep. Then I execute the sweep, pick your profile and then also indicate a base point.
Let me know if this is what you need and if you need additional description of the process.
John Vellek
Message 8 of 14
Jorge.Sanchez
@john.vellek @Alfred.NESWADBA
Hi guys, thanks so much for your prompt responses. A view from below shows that there is an issue and the extrusion profile/shape starts to twist and peel the molding away from the wall and also dig into the ceiling as it follows the path. I would like to maintain the flat surface of the profile/shape against the wall and against the ceiling throughout the whole extrusion. Maybe it has to be done a different way?
Thanks so much for all your help. Please see attached .dwg
Message 9 of 14
SEANT61
This image shows one problem with trying to keep the profile in contact with both the wall and the ceiling.Profile.PNG
May your cursor always snap to the location intended.
Message 10 of 14
Jorge.Sanchez
Thanks @SEANT61
Could I then just run a separate extrusion for the missing gap up against the ceiling? (see image)
How can I keep the original shape from twisting away from the wall and then just adding an extra piece above just for the ceiling?
Message 11 of 14
john.vellek
HI @Jorge.Sanchez,
I am not sure how to recommend proceeding on this. Obviously, a profile can be bent or applied on a curve. It is just when you have such a complex set that it becomes tricky.
i applied your moulding profile on a couple of segments and it can do that fine but where the pieces intersect is where problems arise.
John Vellek
Message 12 of 14
SEANT61
I think the key to creating this Cornice/Crown run, in AutoCAD or in the field, are the transition pieces.  See a partial of what I'm getting at in this file.  A couple of stretches will require some additional piece to fill gap between crown and ceiling.
Message 13 of 14
SEANT61
In hind sight, I would layout that run differently.  That file is still informative, I think, as a demonstration for transition pieces.
Message 14 of 14
parkr4st
Attached almost maybe dwg.
Make your profile a bitoversize so it intrudes into the wall and ceiling.  save a dwg backup.
SUBTRACT the wall and ceiling from the molding.  What is left over should be the piece you are looking for.
The profile and result are off the right in my dwg. Look for a bit of yellow through the top of the ceiling and the weird curves around the circular bends,  Those need fixing
dave
I have it close but hope you evaluate my method and if it works complete your dwg.
