How can I add hatch patterns to AutoCAD 2017 or AutoCAD LT 2017?
john.vellek
Alumni Alumni
Message 1 of 39
john.vellek
I have some hatch patterns from a manufacturer. How can I add them into AutoCAD?
John Vellek
Accepted solutions (3)
Replies (38)
Message 21 of 39
sean.casey
Observer
Observer
Hi Guys,
I'm having real problems installing custom wood hatch patterns which I use to use successfully in earlier releases of AutoCAD. I am currently using AutoCAD 2016 and have tried many different ways of installing the patterns. I am using metric hatches so I expect the pattern file should be a acadiso.pat. I copied the custom files into the end of my standard default hatch patterns and am now wondering if I have gone an messing the up the file fiddling around with it.
Would appreciate it very much if you could look at my attached file and if it works give me a few simple steps on how to load them.
Message 22 of 39
Kent1Cooper
If, by "I copied the custom files into the end of my standard default hatch patterns," you mean [as I assume] that you added them into  acad/acadiso.pat, then they should work unless the pattern definitions themselves have gotten corrupted in the process [and you have that blank line at the end].  I haven't added them into mine to test....  Do the patterns that came in that file originally still work correctly, and only the added ones not work?  Do some of the added ones work, but not all of them?
Also, "I am using metric hatches so I expect the pattern file should be a acadiso.pat " suggests that you may not be sure about that -- ensure that the MEASUREMENT System Variable is set to 1 for metric, for it to use that file.  [You could also add them into acad.pat, too, to cover all bases....]
But if that's a single file separate  from acad.pat or acadiso.pat, you can't have multiple definitions together in one file like that.  Each pattern needs to be in its own file, and the file name needs to match the pattern name exactly, i.e. the file defining the WD4 pattern has to be named WD4.pat.
The latter approach [not changing the standard file] makes migration to newer versions easier, but if you have a lot of them, it means a lot of separate files.  If you add them into acad/acadiso.pat, it's simpler having one file, but at least they should all be together at the end or something, to make it easier to copy them out to add into the same file for a newer version.
Kent Cooper, AIA
Message 23 of 39
john.vellek
Hi @sean.casey,
I looked at the patterns in your file and they appear to be Imperial hatches.  I appended them to the end of my ACAD.pat file (attached) and they load properly.  I also separated each pattern into their own PAT file if that is easier for you to use.
John Vellek
Message 24 of 39
JanneZack
Thank you a million!  Never before has anyone been so clear in their instructions!
Janne
Message 25 of 39
 ACAD 2017 does not have "Trusted Locations" folder. I have followed the steps above but cant complete because the folder doesn't exist. Is there another option or can I not have custom hatch patterns in LT?
Message 26 of 39
john.vellek
HI @Anonymous,
Here is the path where my acadlt.pat is stored on my system.  C:\Users\<USERNAME>\AppData\Roaming\Autodesk\AutoCAD LT 2017\R23\enu\Support
If you do not see a similar path it might be because it is hidden in your appearance settings.
Open your Windows Control Panels, Select Appearance and Personalization, File Explorer Options and then lastly Show Hidden files and folders
Click on the button that is labeled Show hidden files, folders, and drives. Now check to see if that path is available to you.
John Vellek
Message 27 of 39
I posted a location. Will that work?
Message 28 of 39
OK, I've found that location. Do I paste my custom patterns folder or put the files in individually?
Message 29 of 39
john.vellek
Hi @Anonymous,
I am afraid that I don't see the "posted location" you mention in your post.  Was there an image attachment?
At any rate, it is actually a good idea to keep your customization in your own folders and outside of the default folders.
For instance, I created folder on my C: Drive called Johns Hatches.  Once I have it created, I can open my AutoCAD LT 2017 and type OPTIONS. In the Files tab, I expand the top Support File Search Path and then click the add button on the right.  I am now able to use the Browse button to select the folder I created.
Now, when I add custom PAT or LIN files into this folder and then start up my AutoCAD LT, they should be available.
Here is an article that describes the rules for custom hatch patterns.
John Vellek
Message 30 of 39
john.vellek
Hi @Anonymous,
Move the individual PAT files into the location you have created or into the standard Support folder.
John Vellek
Message 31 of 39
Great! They were not showing up when I added the folder in the Options dialogue box but I've successfully gotten some patterns to work after adding them in the support folder. Others are showing errors but some are working. Thanks for your help!
Message 32 of 39
adairHDP5H
I'm aware this question has been asked a million times, but I need to understand how to create a custom hatch and put it where Autocad LT 2016 can find it. I am running Windows 7.
I understand the concept:
Create a hatch .pat file or several
Put them in a custom folder
Put the folder somewhere smart (In the Autodesk folder in the C: drive or in the Autodesk folder in the program files?)
Go to Options dialogue
identify smartly placed folder in the Support Files Search Path.
Then supposedly identify folder as a trusted source.  I have no idea how to do this.
Sadly I seem unable to accomplish any of these seemingly simple tasks. Do I need to restart Autocad each time I try?  Where are the current custom .pat files hiding that I've been using for years?
Every tutorial taunts me with how simple this is.  It seemed simple in every version of Autocad I've been using for 15 years when I could just cut and paste text into a .pat file.
john.vellek has embedded your image(s) for clarity
-Adair
“We are all born mad. Some remain so.”
Message 33 of 39
john.vellek
Hi @adairHDP5H,
It is still allowed to append the data into your ACADLT.pat file if that is the method you prefer. Most users prefer to keep the files separate so they are easier to move, migrate, manage, etc.
If you need help on doing it without adding to your existing PAT file let me know and I can try to help.
John Vellek
Message 34 of 39
adairHDP5H
Thank you for the quick reply.  I don't really care how it is done, I would just like some control over these hatch patterns and I keep coming up with nothing. I literally have been fiddling with this for hours.
What more can I tell you to help sort this out?  I put my hatch patterns directory at the top of my C drive so it is easy to find.  I browsed for it through the Support File Search Path and selected it.
Nothing has changed in my hatch edit dialogue.
-Adair
Message 35 of 39
adairHDP5H
I received some  help on this subject outside the forum.  While I'm not sure what was done differently, all seems to be in order now.  A Utility was mentioned that would help translate custom hatches?  That would be quite handy.
-Adair
Message 36 of 39
john.vellek
HI @adairHDP5H,
Yes, we worked together and changed your Folder Options in Windows so that we could see the Hidden Files and Folders. We checked and found that your ACADLT.pat had some custom pattern files. C:\Users\USERNAME\AppData\Roaming\Autodesk\AutoCAD 2016\R20.1\enu\Support.
We then looked at the unique folder you located at the root of the C: drive.  We started your AutoCAD LT 2016, opened OPTIONS and browsed to the unique folder on C: drive. There is no "Trusted" path to set in AutoCAD LT.
We then verified the patterns were loaded in your Hatch window.
Here is the hatch utility that we discussed.
John Vellek
Message 37 of 39
adairHDP5H
I think I figured out what was wrong.  It may seem obvious to some, but if you come from a background of modifying the .PAT file with additional text, it may be quite confusing.  I guess I am a dinosaur.
When I used to modify the .PAT file, the new options I created would appear at the bottom of the "Other Predefined" Hatch Pattern Palette n the Hatch Edit dialogue box.  If you link to other custom .pat files in an separate directory, they appear in another tab labeled "custom".  There is no graphic preview.  I believe I was simply looking for the new hatch patterns in the wrong place, they were there all along.
-Adair
Message 38 of 39
georgek
Community Visitor
Community Visitor
I followed those instructions and still cannot see any of our custom hatch patterns.   Using Autocad 2018.
Message 39 of 39
cadffm
If your setting is Measurement=0, add it to acad.pat, or =1 for metric files, add it to acadiso.pat
Or save each pattern in a separat file (same name as your pattern), then make sure that acad can find the file.
Keyword: Supportpath
Post screenshot to show us what and where you did *whatever*,
we can not see your monitor.
Sebastian
