Hollow Text in PDF and Layout Tab
philip.schmelzer2
Alumni Alumni
Message 1 of 9
philip.schmelzer2
I've seen a few other posts on this same subject dating back to 2001, where the primary sugestion is to set TEXTFILL=1. Anything else that you can think of to fill in my dimension and callout text? Screenshots below and dwg linked here.
Replies (8)
Message 2 of 9
Patchy
Fillmode
or chck your your text Z elevation.
Message 3 of 9
kcobabe
I opened your drawing in 2014 and looks fine to me.  Not sure why yours is doing this.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 4 of 9
philip.schmelzer2
Thanks for the responses!
Fillmode = 1. Wan't able to check the elevation but I believe it should be standard 2D text. Also running AutoCAD 2015 if that makes a difference.
Message 5 of 9
jggerth
Check the text font file, shx or ttf/otf being used in the STYLE command.  Since the arrowheads are filled, it would seem that the font file being referenced is a hollow outline font.
Message 6 of 9
philip.schmelzer2
Thanks for the suggestion and it is happening regardless of the font that is used and the files all seem standard.
Message 7 of 9
jggerth
well, that looks correct.  And, I can't replicate the issue on my machine.  possibly just a display issue?  is your adaptor on the certified list, and are you running correct drivers for AutoCAD?
And finally, doe it lot correctly?
Message 8 of 9
Patchy
Maybe dview is messing up. Can you open this one and see?
Message 9 of 9
philip.schmelzer2
Turns out it was the Shades of Grey visual style. Changing that to one of the other options (2D Wireframe, Conceptual, Hidden, etc.) resolved the issue. Thanks for the help everyone, especially @quentin.contreras for ultimately finding the root cause.
