AutoCAD Forum
Highest quality in importing a pdf to Photoshop
2 REPLIES 2
4359 Views, 2 Replies
Hi
I have plotted a high-quality pdf in AutoCad which I wish to take to Photoshop. I am not sure which resolution to choose when importing it to Photoshop. When I chose 500 pixels the lines look broken. What is the maximum resolution that you can choose when importing to that the lines stay somewhat even?
Thank you in advance for your help.
- By the way it is a very large pdf that I am importing, appr. 90 x 90 cm. Will making the page smaller but the illustration staying the same size change anything?
Labels (1)
2 REPLIES 2
sophia_lee
Hi @Anonymous ,
Thanks for your post.
I believe you are trying to work on AutoCAD drawings in Photoshop with high resolution. In that case, I would like to recommend you to add postscript.pc3 option to plot as an .eps file. Please refer to the article below;
Hope this is helpful.
Kindly accept as solution if this answers your question. thank you,
Sophia Lee
Global Product Support Specialist
in reply to: sophia_lee
Thank you very much Sophia Lee!
State of Sustainability Webinar
AutoCAD Inside the Factory
