hidden objects and regen speed
Message 1 of 9
If I hide some objects, would they be excluded from regen calculations so things would be faster?
And all hidden objects can be brought back anytime with that little button for object isolation at the very bottom right correct?
What else might hiding some objects have effect on?
Replies (8)
Message 2 of 9
Alfred.NESWADBA
How do you hide objects?
I guess you are not referring to command _HIDE?
Freezing the layer for objects you don't want to see is the option to be best for REGEN performance issues.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
I meant right clicking on object and making isolate, so they are hidden
Message 4 of 9
Alfred.NESWADBA
well, from my feeling freezing layers is the best for performance.
I tried now to create a mass of polygons with each having a large number of segments, then isolated one of these 10000 objects, REGEN was as fast as if the other ones would be frozen.
But I have not found any official documentation stating anything about the comparison between isolating and freezing layers.
- alfred -
Alfred NESWADBA
Message 5 of 9
and how about turning layers off, vs freezing layers? - from your experience I mean... which is better for performance?
thanks a lot
Message 6 of 9
cadffm
AutoCAD must calculate (just) all objects on thawed layers, so it is clear what the answer is.
Sebastian
Message 7 of 9
Alfred.NESWADBA
Draw a line on a layer that is frozen, and then on a layer that is off ... now press <CTRL><A> and then <DEL>.
Now thaw and turn on these both layers and see what happened with the 2 lines. 😉
... that should make it clear as objects on OFF-layers are selectable the performance with frozen layers is better then with objects on layers in OFF state.
- alfred -
Alfred NESWADBA
Message 8 of 9
Thanks... so freeze is definitely better ok.... so turning off is just a visual aid then....
But just I didn't understand the thing you said :
"Draw a line on a layer that is frozen, and then on a layer that is off"
How can I draw on a frozen or off layer in the first place? I didn't understand what you meant there as I couldn't even do it.
Message 9 of 9
Alfred.NESWADBA
sorry, I was too short in my description ... I meant draw 2 lines on two different layers, then freeze one layer and turn off the other layer.  😉
After that check the selection with <CTRL><A>
- alfred -
Alfred NESWADBA
