hidden lines do not appear as dashed
Hidden lines do appear as dashed lines but dash size is too small, and appear as solid line in prints. I'm unable to change hidden line type from small dashes to big dashes from properties>appearance.
Any solution please?
MikeKovacik4928
you need to set your linetypescaling.
you might need to change your PSLTSCALE setting in your viewport your are printing
from PSLTSCALE=0 to PSLTSCALE = 1 or vice versa.
Otherwise you cold click your line and change in the properties dialogue box change
the Linetype scale. This can be trial and error and diificult to get right first time
because the new individual element LTSCALE could be anything from 0.001 to 1000
depending on various factors.
I suggest you look at some tutorials on linetype scaling. There are hundreds around.
Here is just one
http://www.caddmanager.com/CMB/2009/06/ltscale-psltscale-celtscale-and-msltscale/
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (32 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (5 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
