i only know how to draw until here is there anyone can help me with this
?thanks
Solved by Alfred.NESWADBA. Go to Solution.
Solved by Vinayv4v. Go to Solution.
Solved by neaton. Go to Solution.
You need to draw reference arcs for the known distances and the intersection point is the center of the arc. This is a tough one to describe so here is a graphic showing the reference arcs. The red lines are for the 50' arc and the blue lines are for the 80' arc.
Nancy
@Anonymous wrote:
i can't draw the tan arc from the str8 line to the circle
Cheers,
Vinay Vijayakumaran
sometimes parametrics can make things so easy, look to that video >>>click<<< 😉
HTH, - alfred -
