Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
hi i need help my a figure for autocad drawing
4 REPLIES 4
1014 Views, 4 Replies
i only know how to draw until here is there anyone can help me with this
?thanks
4 REPLIES 4
i can't draw the tan arc from the str8 line to the circle
neaton
You need to draw reference arcs for the known distances and the intersection point is the center of the arc. This is a tough one to describe so here is a graphic showing the reference arcs. The red lines are for the 50' arc and the blue lines are for the 80' arc.
Nancy
Vinayv4v
Try the start, end, radius arc.
When the end point is asked to show use the shft + right click and select tangent option from it and click on the circle.
Cheers,
Vinay Vijayakumaran
Alfred.NESWADBA
sometimes parametrics can make things so easy, look to that video >>>click<<< 😉
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
