AutoCAD Forum
hey every one I have lisp which aligning text to polyline parallel,perpendicula
1 REPLY 1
iftikhargulmrd
392 Views, 1 Reply
iftikhargulmrd
hey every one
I have lisp which aligning text to polyline parallel but I want to perpendicular
(defun c:foo (/ _aap l lines p p2 ss text)
;; RJP - 6.14.2017
(defun _aap (ename pt / param)
(if (and (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list ename))))
(setq param (vlax-curve-getparamatpoint ename pt))
(angle '(0 0) (vlax-curve-getfirstderiv ename param))
(if (setq ss (ssget '((0 . "*polyline,Line,Text"))))
(progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(if (= "TEXT" (cdr (assoc 0 (entget x))))
(setq text (cons x text))
(setq lines (cons x lines))
(if lines
(foreach x text
(setq p (cdr (assoc 10 (entget x))))
(setq
l (mapcar
'(lambda (x)
(list (setq p2 (vlax-curve-getclosestpointto x p)) (distance p p2) (_aap x p2))
lines
(setq l (car (vl-sort l '(lambda (a b) (< (cadr a) (cadr b))))))
(entmod (subst (cons 50 (caddr l)) (assoc 50 (entget x)) (entget x)))
(princ)
) but I want to be perpendicular
hey every one
;; RJP - 6.14.2017
(if lines
(foreach x text
(setq
l (mapcar
'(lambda (x)
lines
(princ)
1 REPLY 1
imadHabash
in reply to: iftikhargulmrd
imadHabash
would you check this great link here and see if it's help . >> Click <<
Imad Habash
Imad Habash
AutoCAD Inside the Factory
