AutoCAD Forum
HELP WITH TEXT CONTENT
4 REPLIES 4
398 Views, 4 Replies
I want to select texts and draw lines which is length same as the text content, so that every text have line with length as its content.
So how I get text content to use it in my autolisp script ? note that the text content is always numbers
Thanks in advance
4 REPLIES 4
3wood
DXF code 1 is the TEXT entity string content.
Thank you very much. Is there website that have all dxf codes for all type of objects (text, Line, polyline ... )
Kent1Cooper
@Anonymous wrote:
.... Is there website that have all dxf codes for all type of objects (text, Line, polyline ... )
Check this out.  It's an older one, so it may not have all current drawing entities, but I found it by doing a web search for DXF Reference -- do that, and look around.
Kent Cooper, AIA
3wood
Press F1 in AutoCAD, then enter LINE DXF (or whatever entity type) in the help search box, you will get most answers there.
AutoCAD Inside the Factory
