and @lusofabril
<<... There’s no built-in field function for such a request!!...>>
Although there are no 'built-in' field functions for such a request, there are ways to manage a field.
Yes, it's true you can't (and maybe shouldn't) force a field to function in a certain way you want....but you can instruct AutoCAD to display how the field finally appears in your deliverable. Giving AutoCAD instructions to change the field's appearance isn't the same as changing the field itself.
You, the OP, want to change the appearance of a field because you don't like the way it currently appears--it has too many characters. You know how to acquire the field, you know where to insert the field, but now you want to eliminate one or more characters displayed after insertion. Correct?
In Post #1, you say 'replaces that character with nothing' which means eliminate a character 'in the field's formula.' You only want to HIDE a character when it's inserted, not change what or how the field is acquired.
If you need a specific answer then you'll have to name the specific Field and associated object(s) of the Field. And you'll also need to describe in detail, where you want to insert the field.
Your accepted solution isn't helping you, it's discouraging you. And it not only discourages you, it discourages others who search this same issue, who find this post, and see what you’ve marked as your accepted solution.
Chicagolooper
