Help with array along path...
Thought it would be simple, I wanted to array the top oval object 8 times along the line. But when I choose the path curve/line, and I get the bottom result with the ovals extending beyond the line, what am I missing?
ArchD
You can override how many items show from the ribbon or properties.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
GrantsPirate
Use array rectangular instead, then it is easy enough to adjust to show how you would like.  I think the ARRAYPATH is doing what it is suppose to do, it just isn't what you wanted.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
imadHabash
you can get better result if you change the distance between items ( item spacing ) from Array ribbon contextual tab ( see below image) it will automatically appear up there after selecting your array sample.
Imad Habash
peterm
It is working properly.
You need to adjust the length of your line and the insert point for the oval (see below for original and adjusted).
