Help W/ Trim tool not trimming as expected
aplourdeZ397V
aplourdeZ397V
My trim tool is not working as expected, and I swear it used to work differently.
I have tried many different system variables to fix, but nothing seems to work.
But basically, I am in quick trim mode, and when I go to trim a line, if the next boundary line i want to trim to is off my screen, it will just delete the line instead.
Is there any way to fix this so it will trim to a boundary line even if it is not in my "view"
Please let me know.
  • Trim
aplourdeZ397V
Edit: pretty much if anyone is able to test ok their autocad if I’m tripping about this that would be great. Meaning see if you can trim to a boundary not in view of your screen and let me know!
paullimapa
yep, I can confirm that happens since 2022 will the Trim Quick Mode was added.
Paul Li
IT Specialist
@The Office
tboehler
Try Trimextendmode = 0.  to get the classic trim command.
I'm guessing you're using 2025.  The default trim commands uses all linework as a cutting edge when launched - You could type T and select you cutting edge(s).
paullimapa
Another words the only way is to don't use the Quick mode (this mode did not exists in AutoCAD 2020) which unfortunately the OP wants:
"But basically, I am in quick trim mode,"
FYI @aplourdeZ397V the other way to switch from Quick to Standard mode is at the TRIM prompt:
Paul Li
IT Specialist
@The Office
ВeekeeCZ
This simple lisp line will allow you to do that... unless they are in xref or so...
(command-s "trim" "all" "")
It just selects all objects as trim edges.
