Plot Style Column in Layers Dialog Box
MSchille-1994
MSchille-1994
Anyone having issues with changing the Plot Style of a layer and when you do, the Viewport Plot Style remains as it was?  I change the Plot Style of a layer for the entire drawing from Normal to Black, but the Viewport Plot Style stays set to Normal which makes it a Viewport Override.
This does not happen to any other layer changes such as color, linetype, transparency, etc...
Attitude, not Aptitude, Determines Altitude
paullimapa
Click on Model tab then click back to Layout and the Layer window for that column will update to match
Paul Li
IT Specialist
@The Office
MSchille-1994
hmmm........obviously this is a workaround.  I wonder if Autodesk knows about this workflow flaw.  Color, Linetype, and Transparency do not operate that way.
Nevertheless, thanks for the help.
paullimapa
Yes they do and that is still the recommended solution
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/VP-Plot-Style-does...
Paul Li
IT Specialist
@The Office
