AutoCAD Forum
Help to draw
5 REPLIES 5
s043262
347 Views, 5 Replies
Help to draw
Hello everyone!
Can someone help me to draw this basic figure?
5 REPLIES 5
Kent1Cooper
in reply to: s043262
It doesn't have enough dimensions on it to draw all of it accurately.  Maybe you can assume some things, such as that [for example] the vertical sides of the notches in the top line up with the dimensions along the bottom, and/or that the upper row of hexagons is vertically centered on the Arcs in the ends [and that the right one of those aligns with the left one], but there's nothing by which to locate the Circle.
But for what is knowable, what have you tried, and what are you having trouble with?
Kent Cooper, AIA
Valentin-WSP
@s043262 ,
Agree, assumed info is in RED.
Quick Sample:
  • Use the basic commands under the Home Tab, and the Object Snap for precision.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
s043262
in reply to: Kent1Cooper
It is in 2D, I don't need 3D, I just need commands how to draw it one by one, ty
pendean
and
TheCADnoob
Settings that might be helpful are polar tracking and as others mentioned object snapping
The commands I used are Rectangle, line, Circle, Mirror, Trim, Fillet, Copy, Polygon, Rotate, and Move. Not in that particular order. This may not be the most efficient way to get it done, but it works.
Show your work for us to be able to help you best.
CADnoob
AutoCAD Inside the Factory
