help scaling my viewport on paper space
bazearch
Observer Observer
bazearch
Observer
Observer
Greetings,
I'm looking for assistants in how to scale my viewports for a site plan, I need to get my views to 1"=20' and 1"=50', I used to be able to do this very easily a long time ago but have forgotten now.
Thank You
ennujozlagam
go to paper space > mspace inside your viewport > zoom > type 1/your scaleXP
BeKirra
Enter properties in command line then select your viewport then change the scale in properties dialog.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
bazearch
Observer
Observer
How do you get it set to 1"=20' then once you have it open?
bazearch
Observer
Observer
All I get is telling me to open help
While in your Layout tab, access your viewport and then at the lower right of your screen select the scale that is desired(see image). If the scale is not listed then you need to add it using this dialog box at the bottom of the list.
GrantsPirate
I the newer versions you pick once on the viewport, note a drop down arrow in the center of the viewport, pick that and select the scale you desire.  Adjust the size of the viewport with the grips to adjust for the size of your titleblock, etc.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
