Help On Drawing Lines in Paper Mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm new to Autocad and still trying to figure out the simplest things. In order to enter text on the side of a drawing (like adding your name date and other stuff) to the drawing on the sheet, I need to change from Model to Paper mode.
Once in this mode I can easily enter the text I need. I noticed some spaces on the sheet ar too big and wanted to make them into smaller boxes to more efficiently enter multiple text (see pic below). I managed to add a line shown below. But don't understand how to move/shift it to make it act as a divider between Name 2 and Name 3 below? The current box is too big/a waste of space> Need to add several single lines of text to the sheet and make it look more presentable.
So how to move this line I created? AutoCad keeps snapping the base point to a corner and not the mid point between Name 2 & Name 3. Basically how to add lines as text separator while in Paper mode below?
Need to understand how to do this because also need to add a small image file to the larger rectangle above.
