Announcements
Help needed to know how to remove object lines from overlapping shapes
darius_yang
darius_yang
My student wanted to merge these 3 rectangular prisms but we don't know how to remove the lines to make it onto one uniform shape. I tried "union" but did not work. Please help
https://drive.google.com/file/d/1t267j0_ayNmhLFEc51BQD3BWUkEORpK2/view?usp=sharing
darius_yang
Thanks folks. I forgot to click "enter" when using the union tool. It works now. I still don't know how to remove the line in an arch. I will post another question
paullimapa
Not sure what you mean by removing a LINE from an ARC.
But once you successfully UNIONed the 3d Solid objects, you can move the now single 3d Solid object out of the way or place it on a different Layer to turn off and then do as you will with the LINE or ARC objects left underneath.
Paul Li
IT Specialist
@The Office
