HELP NEEDED TO EDIT A BLOCK - AUTOCAD 2019
apanbasu
apanbasu
I have 2019 AutoCAd. I have copied a Detail numbering block from an architectural drawing, The block is in side the clouded area in the attached drawing.
I could not figure out how to edit it. I tried every thing I know. I tried Edit block in place. I tried exploding the block and edit the numbers all without luck.
Any help will be highly appreciated.
[ @apanbasu This post title has been modified to include the version of AutoCAD - CGBenner -7/22/25 ]
imadHabash
Would you please guide us where to look to find that cloud?😀
Try to make a screen shot and paste it here.
Imad Habash
pendean
Community Legend
Community Legend
@apanbasu FYI your DWG file contains ADT2007 content: if you intend to reshare your file with that user, they are going to get locked out of the AEC content in the file the instant you save it in AutoCAD 2019 (and no amount of saving to an older version will help).
There are no blocks in your top file that you shared
Are we supposed to drill down to others in other folders? Which one?
vinodkl
Hello @apanbasu
Try the attached drawing and see if it helps.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
CGBenner
@apanbasu
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
apanbasu
Thanks.
