Help needed for making a drawing
jaskiratspanesar
Message 1 of 11
jaskiratspanesar
The image of drawing is attached below.
I'm trying to make this engineering drawing but I am not able to make the left side of top view of the drawing.
To me, it seems like some dimensions are missing to draw arcs.
Could someone try to make it and share a video tutorial?
Thanks a lot.
Replies (10)
Message 2 of 11
parkr4st
Layout the guideline geometry from the given dimensions and draw the final lines.  All the information is in the sketch.
some math: R38 + R24 = R62 for the center of the 50 degree arc.
R13 is fillet of the two straight lines
Message 3 of 11
jaskiratspanesar
please check the screenshot below, the angle which I highlighted should be of 50 degrees.
And i have also shared my own drawing, could you explain how you plotted 2nd arc
Message 4 of 11
jaskiratspanesar
I have made it this far.
I still can not understand that math. could you please elaborate
Message 5 of 11
Patchy
No need to do the math, draw it.
Message 6 of 11
jaskiratspanesar
I want to draw the 3rd arc.
Message 7 of 11
Patchy
Trim the circle, you'll get that arc.
Message 8 of 11
j.palmeL29YX
The opposite is the case: If we assume on the left site all arcs/lines touch tangetially, then one of the dimesnions (e.g. the 50° angle) leads to an overdimensioned/overconstrained geometry.
Attached an example which was drawn using constraints. I "ignored"  the 50° angle and got an full constrained geometry.
I you move the inserted image 200 to the right you can compare you image shape with the AutoCAD geometry. To reduce the discrepancies between both I changed the 96 dimension t0 95.
You can play with this file until you get the needed result, as example:
- change the 95 back to the initial 96 (double click at d6 and change the value) and see what happens
- add the 50° angle if you urgently need that value (you must delete one of the tangential constraints before) and see what happens.
- Play with changing other dimensions and or geometrical constraints. We (I) can not know how the shape should look at the end.
Jürgen Palme
Message 9 of 11
parkr4st
Thanks to the others it looks like you have a solution.  I didn't catch the 50 degrees earlier as I had to get to work.
But the question I have now is if that is top and front view, why is the front view wider than the top view?
Message 10 of 11
j.palmeL29YX
@parkr4st wrote:
... if that is top and front view,
the two views obviously do not show the same part
Jürgen Palme
Message 11 of 11
jaskiratspanesar
Yeah, you are right. The front view is wider, which is obviously wrong. I think someone mistakenly stretched it as number or projections are correct
