Help index
Help index
peterm
Message 1 of 20
Help index
peterm
Where do I find the help files for AutoCAD 2018?
In other words, where should the Help location search path point to?
Replies (19)
Message 2 of 20
imadHabash
Him
does this help from OPTIONS command.
Imad Habash
Message 3 of 20
GrantsPirate
Options>Files, expand Help and Misc File Names
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 20
peterm
Hi Imad,
What I need to know is the location of the help index file so that I can point to it.
Message 5 of 20
sthompson1021
I may be wrong and if I am I'm sure someone will jump in to correct me but if you are looking for the help files saved on your computer, I don't believe there are any. I seem to remember something about help being available online only. In the past you could download help but I'm not sure if you can anymore or not.
Message 6 of 20
peterm
Okay. So when I press the little question mark in the top right hand of my screen, why does it say it can't find the file?
Message 7 of 20
imadHabash
you may need to download offline help files to your local drive. >> Click <<
all the best ,,
Imad Habash
Message 8 of 20
peterm
So, where should this point to then?
Message 9 of 20
sthompson1021
Couple more thoughts on this.
1. My help location points to the same place except it stops at help. It doesn't have the \webbrw.chm behind it.
2. Below the help location, is your default internet location set to http://www.autodesk.com
3. On the Systems tab in options, under help, is the access online content box checked?
Message 10 of 20
peterm
Okay, I changed the help file location and checked the internet location:
I can't see anything to do with Help or online content under the system tab:
This is what I get when I click on the question mark:
Message 11 of 20
GrantsPirate
On mine the path is
C:\Program Files\Autodesk\AutoCAD 2018 Help\English\Help\index.html
GrantsPirate
EXPERT ELITE MEMBER
Message 12 of 20
peterm
That doesn't work for me as it is looking for a .chm file.
Message 13 of 20
sthompson1021
Are you using plain Autocad or one of the verticals. My system tab looks like this
Message 14 of 20
peterm
It's vanilla AutoCAD, but came as part of the Mechanical installation.
Message 15 of 20
sthompson1021
Does Help work if you are running as Mechanical?
Message 16 of 20
peterm
Wierd. AutoCAD Mechanical works as it is using a .html file:
Also, the System tab shows the online help bit as well:
So the question remains: how do I access help files in AutoCAD 2018 (not mechanical)?
Message 17 of 20
gotphish001
I'm not sure about the help, but I know if you remove all the paths for where palettes are stored and apply and close. When you open options again it put the default locations back in. Maybe try and just remove what you have and apply and close, maybe a restart of autocad. If nothing is there it might re-add the default.
EDIT: I just test it. I changed my help location to some random stuff I just smashed on the keyboard. Applied and saved and closed options. Reopened options and my new location was still there. I removed that location and left it blank, applied and closed options. Reopened options and it put back in my original location instead of rolling it back to the location that I had just removed and made up anyway.
Nick DiPietro
Cad Manager/Monkey
Message 18 of 20
sthompson1021
Not sure if you can directly from the program. This post is from 2016 so not sure if its the same or not.  https://forums.autodesk.com/t5/autocad-mechanical-forum/how-to-view-autocad-2016-help-in-mechancial-... You might want to post in the Mechanical forum.
Message 19 of 20
peterm
I tried that. The problem is that the default location doesn't work.
The AutoCAD Mechanical files are stored as a HTML file, but vanilla AutoCAD is looking for a CHM file which doesn't exist.
What I need is a help file called index.chm.
Message 20 of 20
peterm
Well, I finally gave up and went the long way round.
Instead, I've moved over to AutoCAD Mechanical where the help file works and I've tweaked everything to look and work the same as standard AutoCAD.
Thanks for all the help and suggestions.
