HELP: I can't type measurements when creating a rectangle
N00406026
N00406026
Community Visitor
Community Visitor
Naturally, when you make a rectangle in the program, you can type the measures or numbers, for example, 60 comma 60, to make a square.
But for some reason I do not longer have the option, it does not appear, and if I try to do it through the properties, it becomes 3D.
Tomislav.Golubovic
dynamic input on?
paullimapa
Can you do a screenshot of what you’re seeing on the screen with the command prompts as you attempt to draw your rectangle?
Paul Li
IT Specialist
@The Office
imadHabash
You can get it either by typing @60,60 OR make sure that Dynamic Input (F12) is ON .
Imad Habash
jskalaXDDX5
CUI Macro, create button or shortcut menu?  Saves some keystrokes maybe...
^C^C_RECTANGLE;\DIMENSIONS;\\;
