help - autocad locking up on opening drawings - stuck at initializing plot settings
rbarnard
rbarnard
like title says, appreciate some help, autocad (19, 20, 21, 22, 23) is locking up on opening drawings now - all get stuck at initializing plot settings, tried recover, but no luck.   have to either wait like an hour or force close.   uninstalled and even reinstalled acad, tried different versions, all have same problem.   thanks
pendean
Community Legend
Community Legend
Log into your PC as an all new user with admin rights (involve your IT if that is a requirement) and see if the issue persists.
And remind everyone here what is your exact OS please, and what changed on your PC recently, as something did for sure.
paullimapa
I would try first going to Windows Control Panel > Autodesk Plotter Manager
Remove any PC3 files that may be suspicious
Then  Windows Control Panel > Autodesk Plot Style Manager
Remove any CTB or STB files that may be suspicious
Paul Li
IT Specialist
@The Office
TomBeauford
Does it happen with all drawings?
When you first open AutoCAD to the default drawing1 from your default template does it happen?
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
ijscarberry
Hi rbarnard, I am currently having the same issue. Do you remember what you did to fix this issue?
paullimapa
There was no acceptance by @rbarnard on any of the solutions posted here. Have you tried reading through this thread and trying the solutions yourself?
Paul Li
IT Specialist
@The Office
