Help adding paper sizes in AutoCAD
Message 1 of 14
Hi ,
This is Ruaa Katto , work at Trinity Steel Inc. I am using AutoCAD 2017 , trying to add new paper size to plot a full size drawing for shop but can’t click on the Add , delete or edit batons on custom paper size.
Please see attached picture for more information .
Please let me Know what to do , why it is not effective .
RUAA KATTO
TRINITY STEEL
[email protected]
@Anonymous,
john.vellek has edited your subject line for clarity: help need
Accepted solutions (3)
Replies (13)
Message 2 of 14
Alfred.NESWADBA
if that button "Add" is active or not depends on the printer driver. Some printer drivers have the option to add the page formats directly in the system printer console, if that is working then you can't add them to the AutoCAD definitions (PC3/PMP), you have to add your special formats in the system printer properties.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 14
AllenJessup
Often you can assign new pater sizes through Custom Properties. The image below is based on our HP510. As @Alfred.NESWADBA mentioned, this may vary from driver to driver.
Allen Jessup
CAD Manager - Designer
Message 4 of 14
john.vellek
Hi Ruaa,
Check out this older post and see if it helps you to add a custom sheet size. If not, please add a post and I will try to find you some additional resources.
John Vellek
Message 5 of 14
Thank you  Alfred
I think that is the problem , the printer, because I add new custom size to the printer yet it is not showing in the menu when I try to choose the paper size.
Ruaa
Message 6 of 14
Hello John,
I have tried every single way to do that yet it is not working , I think the problem is with the printer it self or the new system , because it was the same printer when I was able to change paper size , same printer with old auto CAD version , I don't Know what happened  .Smiley Sad
Ruaa
Message 7 of 14
Thanks Allen
Yes I agree with you that the problem is with the printer .
Ruaa
Message 8 of 14
Alfred.NESWADBA
Did you restart AutoCAD after modifying the printer's paper sources?
Which printer and which printer driver version are you using?
- alfred -
Alfred NESWADBA
Message 9 of 14
AllenJessup
Have you tried updating the printer driver?
Allen Jessup
Message 10 of 14
Yes I did , I restart the computer also not only the autocad.
Message 11 of 14
hi Alfred
the printer is HP design jet T 795 44"
it is the same printer that I work on it before  insulting windows 10 and auto CAD 2017
Ruaa
Message 12 of 14
Hi Allen
I was not able to do that because the advanced properties are not active;
Ruaa
Message 13 of 14
Alfred.NESWADBA
Well, in the past we have noticed that HP does not do a great support for Windows 10, older devices don't get (correct) driver updates and it's annoying what HP does (or better does not).
If you have updated an older Windows to Windows 10 then you should uninstall the driver, look to a driver that is specific to that plotter and definitely for Windows 10, if you don't find such a driver you might go the way to use an universal plotter driver from HP, which does not support specific functions for your plotter, but at least works with Windows 10.
Good luck, - alfred -
Alfred NESWADBA
Message 14 of 14
Alfred,
Thank you so much for the information that you give me, I will contact with the person that update the system and install the new sever to try to fix the problem. Smiley Happy
Thank you
Ruaa
