Having trouble with datalinks
Hello everyone. First post here. Fairly new to AutoCAD. (I miss SolidWorks already!) I'm getting really frustrated with datalinks. I'm probably missing something obvious!
I'm having two main issues, both to do with formatting. I got a datalink to work fairly well, however some of the formatting isn't copying over from Excel. The font is right, the justification is correct, but that's about it. All the words within the boxes are changed to the same font size / text height. The Excel spreadsheet did have several cells with the text "shrunk to fit," and I tried to solve the issue by going through and manually changing the font size of those cells, with no luck. I was able to manually go through and shrink the text in each box that was wrong, but that was way too time-consuming. Also, the embedded table in AutoCAD seems to be just picking whatever column widths it wants when it creates the table. I can change it manually, but it's pretty annoying. I'll be doing this a lot...
My other main issue is that I only got this ONE datalink to work. I'm not sure what I did, but it looked pretty good right off the bat when I inserted it. I tried creating one on a new drawing, and NONE of the formatting was copied over. All the cells/boxes were the same height and width, the font was changed to the default style and size, and centered in the boxes, etc. Just completely off. I'm not sure what I did differently but I can't make it look like the first one I did. Help please!
Screenshots:
Excel sheet http://i.imgur.com/analqtP.png
What the table looks like before I manually change the text sizes http://imgur.com/7a87SBn
What every other table looks like I try to insert http://imgur.com/RT4iWgV
