I made a CUIX, in it 2 customized workspaces, which i copied to ACAD.cuix
I only see the Exspress tab, i have to invoke the RIBBON command each time i switch to an othe, original, workspace and back
Hi, if you want, I'll take a closer look at the matter.
I can't follow the text alone - it contradicts my knowledge of how things (should) work.
I would also be interested to know whether the situation changes if you load your CUIX file as Enterprise.
1. Unload your .cuix
2. Delete the relevant workspaces in the main cuix (acad.cuix?),
3. Attach your .CUIX as Enterprise
In this configuration, you do NOT need to copy the workspace, it happens automatically.
However, I will not spend any time trying to reproduce the problem somehow,
I would try it if I had your export settings package.
Export Setting as .zip and share the file (public or private, it's your choice)
Sebastian
Sebastian
Loaded as enterprise - the same, no ribbon until RIBBON command.
Loaded again as normal, saved profile as *.arg and zipped
I don't know how to export settings, save to export profiles
Autocad 2021
Autocad 2021
"I don't know how to export settings"
In your OS windows search: Type in EXPORT
or read this
Thx for sharing the profile too, but a profile does not containing your customization user interface / cui(x)
Sebastian
or read this
Sebastian
I must haven't installed Export settings Autocad 2021, i only have installed that of 2013
I attach them here and am going to install for 2021
That's not an option so far I know.
But okay, press [WIN]+[R]
open: "C:\Program Files\Autodesk\AutoCAD 2021\AdMigrator.exe" /e /product ACAD /language "en-US"
I attach them here
And there are the same cuix files attached as in 2021 with the same ws/Ribbon issue, or why you sharing this package?
Sebastian
I attach them here
Sebastian
okay, I checked your .zip by a short look - I see the issue,
but I can't answering now, sorry.
Sebastian
Sebastian
Well, are you going to hold me in tension?
Lol, that's not the reason.
If I am back at Acad with time I need, I will answer in detail.
Sebastian
Sebastian
