AutoCAD Forum
Hatching and 3D issues
1 REPLY 1
braicodavid
202 Views, 1 Reply
So I've gone through some threads and I can't find a solution.
I viewed this; https://forums.autodesk.com/t5/autocad-forum/hatch-freezes-autocad-2016/td-p/5616371
but I'm still getting issues.
I think my problem is that I import 3D blocks into the drawing and it struggles to constrain to a plane. I use the FLATTEN and FLATSHOT commecnds but they don't fix my issue.
Is there a way to be able to constrain everything to a 2D plane and get rid off the 3D aspect. I realise every time I import a 3D block it cuases issues so, i just need some easy fix that allows me to keep everything on the one plane.
David
1 REPLY 1
ennujozlagam
in reply to: braicodavid
@braicodavid i think you need to explode 3D blocks before you can flatten the objects. or post the file so we can check. thanks
AutoCAD Inside the Factory
