Hatches triangulate when plotting to pdf
nickLQFNV
Message 1 of 12
nickLQFNV
I've come across dozens of threads on this issue from 2005-2018, and it seems like this problem hasn't yet been properly addressed, so I apologize if any of this is redundant but I haven't yet found a satisfying explanation of why this behaviour still exists in AutoCAD after 2 decades.
When I plot to pdf (AutoCAD General Documentation), all of my solid hatches are broken into small triangles. My understanding is that originated as a quirk of printer technology, which could only interpret solid regions as being described by three points. Any more corners or rounded edges, and the solid hatch will be divided into 2 or more triangles. This is of course noticeable as thin white lines when zooming in and out in a pdf reader, but can also make life difficult when using a vector graphics editor to bring a drawing up to a presentation quality. Depending on the conversion process, the lines are visible after converting to raster data.
I've come across a number of threads offering workarounds which include turning solid hatches into gradients with 2 identical colours (which will rasterize the hatch data), adjusting pdf viewer settings (which doesn't help while editing a pdf), and increasing the quality by changing plot settings or selecting a different pdf maker. None of these actually seem to address the core issue which is that AutoCAD seems to be incapable of making pdfs with simple shape fills that other vector graphics software can do without issue.
Is there a way of getting AutoCAD to properly plot solid hatches to pdf as single objects with multiple vertices? If not, why does it still do this, given that the vast majority of CAD work is done through the pdf format?
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
There is no cure, you have to decide what to live with.
Autodesk says...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/PDF-print-generate...).
and
This works for most stuck using only Adobe Acrobat
https://www.landfx.com/kb/autocad-fxcad/plotting-images/5214-pdf-stripes.html
In the meantime... Show us your issue: post a PDF with the problem present and the source DWG the example came from please.
Message 3 of 12
nickLQFNV
Thanks for the response, I figured that was the case. I'll likely stick with the transparency settings that cause the hatches to rasterize, since I typically don't need to edit the actual hatch geometry after exporting to pdf. Seems like there's no solution, only workarounds.
Do you know why this is still the way AutoCAD handles plotting solid hatches? I'm just curious.
The files and issues are identical to the problems that people have been having with this for 20 years, skittering lines appearing across solid hatches. Here's a rectangle and circle that have the same behaviour, I've attached a pdf and the dwg here. The screenshot is from Affinity Designer.
Message 4 of 12
pendean
Community Legend
Community Legend
@nickLQFNV wrote:
...The screenshot is from Affinity Designer.
this is from FOXIT PDF EDITOR
This if from CHROME (yes, the browser)
From EDGE (yes, the other browser)
Adobe Acrobat (with these display settings)
See above FOUR sample, seems challenging to me anyway, you want to take a stab at fixing it for them?
Message 5 of 12
nickLQFNV
In FOXIT, can you select the circle as a single object? I'm not concerned with the appearance in software, as there's workarounds for that. I would still like to be able to export a pdf with solid hatches that are a unified single object within their boundary, which would make later edits to the pdf easier. I'd prefer to be able to select one hatch instead of 50 narrow triangles.
Message 6 of 12
pendean
Community Legend
Community Legend
@nickLQFNV wrote:
In FOXIT, can you select the circle as a single object?..
No. That's a limitation of your software with output from Autodesk. I suggest you try a different software for the task you want, Adobe Illustrator.
Interesting programming dilemma, huh.
Message 7 of 12
nickLQFNV
When you say "limitation of my software," you mean that's an inherent function of AutoCAD?
But yes, if I really need the solid hatches to be single solid vector hatches, I'll draw the outlines (or use HATCHGENERATEBOUNDARY) and swap the fill & strokes in my vector editor.
Message 8 of 12
pendean
Community Legend
Community Legend
Your software (below) and AutoCAD I suspect are not designed by both software vendors to work together to meet your workflow needs
Message 9 of 12
Simon_Weel
If a PDF needs to look 'clean', i.e. the solids have to be, well, solid, we don't use solids. Instead we use a very fine spaced line based hatch angled at 45 degrees. You might have to fiddle the density / scale of the hatch to get the best result.
Message 10 of 12
nickLQFNV
The triangulation is noticeable in any program, I've come across it in Illustrator, Acrobat, and even in bringing a pdf back into AutoCAD. It doesn't matter what the vector reader or editor software is when the files in question will always have this behaviour. I do appreciate the responses and expertise, thank you for your time.
Message 11 of 12
cpaveglio
Community Visitor
Community Visitor
I have this same issue, and I find it depressing that AutoCad is like this. I honestly want AutoDesk to FIX IT. The core problem is solid hatches are drawn into triangles, and that should not happen in 2025 in PDF exports. It's a huge amount of work to open the PDF into any vector app and try to edit the filled shapes as a single shape, it should be a single shape with a complex outline, not 300 triangles. Rendering a shape as a pixel object/embedded image is not a solution either.
My example use case is: get PDF from architect/engineer, open in Illustrator, edit the objects to make it more presentable, offer alternative designs (think clients that want new ideas or zoning boards that don't need all the detail) and I do not have access to the original DWG. All I have is a PDF.
I understand software development can be tough to go and fix "old" core features. But it's showing it's immense age with terrible graphic handling like this triangle issue. Something like this should have been on a migration plan 10 years ago, and worked on a little at a time until it could be rolled out with little impact to users on old computers/OS/etc.
Message 12 of 12
nickLQFNV
It's baffling to raise this issue and be met with the level of derision that some people on this forum bring to a basic functionality request. "Creating filled polygon vectors" isn't some kind of earth-shattering technology in 2025. Seems unfortunate that Autodesk isn't interested in advancing one of their flagship products, or expanding its use cases/user base. Insisting that the deficiency is with the user's computer or pdf viewer/editing software is absurd when it's clear that AutoCAD is *simply not capable* of plotting a filled vector with more than 3 points.
There are workarounds, but each has it's own drawbacks. Plotting a gradient or transparency will pixelate. Plotting a dense line hatch means excessive vector information in the pdf, and the result is completely unworkable if you want to further edit the hatch in pdf.
If you want to jazz things up in Illustrator, a quick(ish) way to get nice solid hatches is to just draw the outline of the hatches on their own AutoCAD layer, plot the sheet, then open the pdf, select all of those polylines and swap fill & stroke. You can even keep the hatches in the drawing, set the hatch layer(s) to non-plot, and run "HATCHGENERATEBOUNDARY" when you want to export a pdf you intend to open in Illustrator.
