Hi @Anonymous
1. AutoCAD crashes or freezes when running the HATCH command Click here
2. How to improve performance in drawings containing hatches in AutoCAD
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Type 3DCONFIG(enter) turn off Hardware Acceleration.
Type SELECTIONPREVIEW(enter) provide value 0
SALMANUL FARIS
>> AutoCad often chrashes when I use the Hatch command
Can you recreate the crash in a new dwg-file (new drawing based on an original AutoCAD template)?
If not it might be your dwg-file (maybe referenced files in your dwg too). Run command _RECOVERALL instead of _OPEN to see if there are errors in the dwg-file(s).
Also make sure you have saved your dwg-files in the current file format and not in older dwg-formats.
- alfred -
