hatch transparent on plot
archsol2022
Message 1 of 12
archsol2022
I am facing a problem with autocad plotting, i have a plan with multiple hatches, set with various transparencies.
If I create a PDF (using DWG to PDF.pc3) with 'plot transparency' checked, the PDF looks fine, but when i try to print it some part of hatches missing and some lines also.
Thanks you
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
What does the DWG or PDF content look like? Showing us the paper result alone is not as informative sadly.
Message 3 of 12
paullimapa
If the transparencies look fine on the pdf but shows missing items on the hardcopy then this sounds like your plotter problem. Do you have a different plotter to send the same pdf file to as a test?
Paul Li
IT Specialist
@The Office
Message 4 of 12
archsol2022
Here is the pdf file
Message 5 of 12
archsol2022
yes i print it with several of plotters in the office and the problem is still the same
Message 6 of 12
paullimapa
What program are you using the open and print the pdf to the plotter?
Paul Li
IT Specialist
@The Office
Message 7 of 12
pendean
Community Legend
Community Legend
Thank you for the PDF. Your missing very faint-colored door/window frames print just fine (and faint) on our color laser printer, our B/W laser printer, and our color Plotter. There is nothing wrong with your PDF output here, sorry.
Message 8 of 12
archsol2022
Hello again, i am using Adobe Acrobat DC
Message 9 of 12
paullimapa
time to try using a different pdf viewer to see if you're successful in printing those pdfs.
Paul Li
IT Specialist
@The Office
Message 10 of 12
archsol2022
Hi again, what do you suggest to do? I tried converting it to an image to see if there was any difference and I can say that it was somehow better. Does it make any sense that when I converted it to an image it had a better resolution when printed?
Message 11 of 12
pendean
Community Legend
Community Legend
Change the color/pen assignments to the vanishing elements to a heavier lineweight to see if your various plotter can cope better.
If you want, you can also share your actual DWG file here please: lets understand your vanishing elements settings better.
Message 12 of 12
archsol2022
i think i have the solution from a previous answer, i changed the pdf viewer from Acrobat to microsoft edge and i have to say is way better than previous. some spots is not perfect but its acceptable
