Hatch transparency can't work when selecting hatch editing
Message 1 of 9
Dear Autodesk Technicians,
Have a good day.
Now i am facing hatch transparency when i edited hatch. (it occurs solid hatch instead of transparency hatch)
I can't see under layers and so i can't move vertex points to the exact point because i can't see under layer.
I made layer send back but it can't work.
Could you please help a problem that i faced? Please check the attached photo and let me know the solution.editing hatch can't see under layersediting hatch can't see under layers
Replies (8)
Message 2 of 9
vinodkl
Does "HATCHTOBACK" solve the problem?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 9
Hatch to back can't solve the problem.
How to change solid to transparency viewing when editing?
Thanks for your reply.
Message 4 of 9
ennujozlagam
why did you mark as accepted solution when didn't solve your problem?
you can try this pick your hatch and adjust your hatch transparency, and  right click > draw order > send to back. please see attached and see if helps. thanks
Message 5 of 9
vinodkl
Check if "TRANSPARENCYDISPLAY" is set to "1"
If problem is not solved, please post the drawing so that we can investigate.
Message 6 of 9
Thanks for your kind reply.
It doesn't work with TRANSPARENCYDISPLAY set to 1.
Please let me explain error.
I would like to edit hatching with vertex on the hatching.
Other pc autocad, fine conditionOther pc autocad, fine condition
This is fine condition with other pc autocad.
my pc autocad, can't edit with vertex pts on hatchingmy pc autocad, can't edit with vertex pts on hatching
This one is problem in my pc. I can't see under layer because of selection on hatch is solid instead of transparency.
Could you please solve this problem and thanks for your kind support.
Message 7 of 9
vinodkl
Can you check the "3DCONFIG" and try turning it ON? Hope this solves your problem.
Message 8 of 9
Thank you so much for your support.
Message 9 of 9
James-MacLellan
This was the problem! Thank you.
