Hatch solid color not showing up autocad 2020
jeff
jeff
I am trying to hatch boxes in my drawing.  The color does not show up when selecting solid hatch.  The box is still black.  The patterns show up if I use any other type of pattern other than solid.  I have searched the forum looking for an answer with no success.
I am grateful to any help given.
Thank you,
Jeff Otto
cadffm
If you talk about preview and plot,
and if you have another software(AutoCAD for MAC, here is Autocad "for Windows")
Is your transparency level 90? Try 60 for a plot.
Sebastian
jeff
It does not show color hatch in box with transparency at any value.
Thank you,
Jeff Otto
Alfred.NESWADBA
In general: To see a box filled I would use a visual style like "Conceptual" or "Realistic" which shows the content in a rendered style.
As one guess: hatching an object (in 3D space) means you need first to set the UCS to the plane where your object to hatch is placed. So for your 6 sides of the box you'll need 6 different UCS to hatch all sides.
You might also upload the dwg-file so we see why your hatches don't show up.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jeff
I am drawing on z axis of 0.  I attached a copy of dwg file.  There is a large box and a smaller box next to each other.  I hatched both.  They both appear black.  The smaller box has to be hatched in the drawing. I have green and yellow boxes to hatch.  I also have a block with reference material in it.  The boxes noting layers are also black.  When I go into block editor, they show the correct colors.
Here is a link if you would like to view: https://drive.autodesk.com/de29d2110/g/shares/SH56a43QTfd62c1cd968dfd845593e0f162e
Thank you so much for helping me.  I am a self taught autocad user and am probably making some elementary error.
Jeff Otto
Oak Hill Model Railroad Track Supply LLC
Alfred.NESWADBA
please change your visual style to "2D Wireframe", it is set to "Hidden".
BTW:
Box is a 3D object, not a rectangle (in terms of AutoCAD) 😉
- alfred -
Alfred NESWADBA
jeff
Alfred,  Thank you very much!  I knew it was something simple.  I will have to write that down on my notes in case it ever happens again.
Have a great rest of your weekend!
Jeff Otto
Owner
www.ohrtracksupply.com
