Hatch selection
Hatch selection
Hatch selection
Hi. Im using AutoCAD LT 2016. I select a hatch and then pick or select areas/object. Once entered and I wish to repeat that hatch style the tab comes back to the default style, not the one I previously selected. Can I change a setting so I dont have to keep resetting the hatch for every selection?
oswaldodcb
Hi @Anonymous
Has this ever happened to you? Or from a moment you began to notice that change?
What I would recommend is that you restart the default values ​​of the program and so you can verify that it is not a system variable that is affecting you,
Before resetting you can make a copy of the configuration, so if you do not see any improvements you can re-import your previous configuration,
I attached the link for you to review the information,
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-import-and-export-backup-settings-to-and-from-AutoCAD.html
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoCAD-to-defaults.html
Let me know if you could solve your problem,
I remain attentive to any other doubts,
If my publication solved your concern Accept the SOLUTION
Oswaldo Caballero
Instructor ATC
Autodesk AutoCAD Certified User
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
imadHabash
Hi and Welcome to AutoCAD Forum,
>> Once entered and I wish to repeat that hatch style the tab comes back to the default style, <<
does your previous preparation for hatch finished successfully and you see your selected hatch? make sure that happened.
>> Can I change a setting so I dont have to keep resetting the hatch for every selection? <<
you can get your previous hatch settings by using ADDSELECTED command.
Imad Habash
