Hatch problem ?
Hatch problem ?
Message 1 of 12
Hatch problem ?
Can you take a look at the attached screen shot & tell me why there the white lines across the hatches. They only show up on a PDF, not in autocad print preview. It all started when I added shading/ shadows
Tess
Replies (11)
Message 2 of 12
Alfred.NESWADBA
And I guess only when you use Adobe Reader as PDF-viewer ... sorry for just guessing, but you have not attached the PDF itself as well as not the DWG-file to see if we can find settings that are making that display issue.
If I'm correct with "only Adobe Reader" then you might look to the options of Adobe Reader and look to these settings (play with them) ... as shown in >>>that thread<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 12
Hi Alfred
Ive made to changes to Adobe from the thread you attached, but it made no difference, I have attached the PDF. I should say when you open the PDF it is fine, the problem occurs when I email the  PDF
Tess
Message 4 of 12
Alfred.NESWADBA
ok, I can see the diagonal white lines too, can you please upload the dwg-file so we can search there for the source of this issue?
Also start command _ABOUT (in AutoCAD) and send us a screenshot from that dialog to know which type and version of AutoCAD you are using.
BTW: mailing a PDF does not change the file, so I doubt that mailing makes the difference.
- alfred -
Alfred NESWADBA
Message 5 of 12
autocad about.jpgAttached is the info
Message 6 of 12
Alfred.NESWADBA
sorry, that screenshot is much too small to see anything on it.
Can you write down the version information from line 2 in your screenshot?
Also please upload the dwg-file. Otherwise we have to guess all the time.
- alfred -
Alfred NESWADBA
Message 7 of 12
Hi Alfred
The Number is G.55.0.0
Tess
Message 8 of 12
Alfred.NESWADBA
Which means you have not installed your latest service pack for your AutoCAD 2013 (I guess it's 2013).
To come more close to: "what to change in the drawing to make that hatch looking well in the PDF" we would need the dwg-file as next.
- alfred -
Alfred NESWADBA
Message 9 of 12
j.palmeL29YX
Without knowing your.dwg, I can only guess too:
Maybe your model is drawn far away from the origin point (?). Solution: move te model close to the origin point 0,0 or define the base point of the hatch close to the model.
Jürgen Palme
Message 10 of 12
rkmcswain
@Anonymous - I don't see anything wrong with that PDF.  Try another PDF viewer. I'm using Bluebeam 2018.4 (top two screenshots) and it looks good. Same for Adobe Reader DC 2019.010 (bottom screenshot)
Message 11 of 12
Just to make sure, Ive opened the cad drawing & its fine, Ive opened the saved PDF & its fine, Ive opened the email with the PDF attached I sent to the client & the drawing has the white stripes on it, its it my email?
Message 12 of 12
s.borello
It may be your PDF reader... try downloading another one and do a test to see.
