Hatch Pattern Scale `rounded`
I am having an issue with hatch pattern scale. When I input any value, it rounds it up to the closest decimal i.e. 0.05 becomes 0.1, 0.04 becomes 0, etc. Any idea what is causing this? Its the first time I encounter this, the file works well otherwise and the hatch is a default AutoCAD one.
Kent1Cooper
Is it just a matter of display settings?  If it's in the Properties palette or the Hatch Editing part of the ribbon that you're seeing this, it probably "knows" the right value but only displays the rounded version.  Go into UNITS and see whether the precision there is set to display only one decimal place.  And for 0.04 becoming just 0, check the DIMZIN System Variable about whether trailing zeros are suppressed.
Kent Cooper, AIA
