HATCH NOT SHOWING UP IN DRAWING
jbaldeo
Message 1 of 11
jbaldeo
Hi everyone I need some help with my hatch issue. I have opened a drawing that was created in Autovad Realease 12 and tried to hatch a part of it in Autocad 2016 but the hatch patterns are not showing up and it does not matter what hatch pattern I use, any suggestions ?
Replies (10)
Message 2 of 11
Alfred.NESWADBA
As that seems to be drawing dependent please upload the drawing and show us the object you'd like to hatch so we can test it on our systems.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
pendean
Community Legend
Community Legend
Post your DWG file here and identify where we should be looking.
Message 4 of 11
john.vellek
HI @jbaldeo,
I assume that you have tried different scales of the hatch patterns.  Is the file Metric or Imperial?
Try running AUDIT on the file as well as PURGE.  Then apply a hatch with different scales to see if it shows up. I am happy to look at the drawing file too to see if this is indeed the issue or if there is something else going on. If you would like me to do this please attach your file to a post.
John Vellek
Message 5 of 11
Vinayv4v
Did you check the scale for hatch?
After applying the hatch change the scale value and take a look.
Cheers,
Vinay Vijayakumaran
Message 6 of 11
imadHabash
>> but the hatch patterns are not showing up and it does not matter what hatch pattern I use, any suggestions ? <<
you may hatch on already turn off layer. you may need to check your layers status.
Imad Habash
Message 7 of 11
jbaldeo
I have tried almost all the scales and all my layers are turned on, unfortunately my boss could not wait for a solution because the job was a priority so he did what I told him not to do which is copyclip and pasteorig to a new drawing template and overwrite which worked but now I don't have the drawing. The drawing was from realese 14 version. Thanks anyway everyone.
Message 9 of 11
chriscowgill7373
(setenv "MaxHatch" "10000000")
(setvar "HPMAXLINES" 10000000)
could be a couple reasons the hatch didnt appear correctly.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 10 of 11
jbaldeo
Thanks everyone, those solutions sounds promising, unfortunately I lost my drawing is no longer available so I do not know what would have been the final solution, but I believe the fill and the system variable maxlines might have helped, maxhatch is not recognised in this version. Again Thanks everyone
Message 11 of 11
PharesOfThemAll
Thanks for the tip!  I just updated to AutoCAD 2018 for Mac and the same issue occurred.  My "HPMAXLINES" was preset to 100000 and I couldn't see anything but when I adjusted it to 10000000 my hatches showed up.
