Hatch fade in single hatch
niteshparajuli
niteshparajuli
Is it possible to have the hatching fade (become more transparent) so the hatched object is completely hatched up one end and then progressively transition to completely transparent at the other?
imadHabash
Select that hatch then press Ctrl+1 .. now change the transparent value .
Imad Habash
niteshparajuli
Thanks, Imad. Is it possible to change the transparency gradually from one corner to another corner in the same hatched area(from higher to lower number of transparency)? Something like gradient hatch but in pattern hatch.
Valentin_CAD
@niteshparajuli ,
No.
The transparency option does NOT allow for a "gradual" fade - similar to gradient.  In addition, the gradient is not applicable for pattern hatch.  Its an interesting request that could be submit to https://www.augi.com/wish-list.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
schurthing
Although your question is about a single hatch object, depending on what you are trying to achieve, it is possible to approximate the fading style by overlapping multiple hatches.  It might not be the solution you are looking for, but it is easy enough to do and could be good enough.
Stefanie
crazy autocad witch since release 8 😄
niteshparajuli
Used it. Thanks, Stefanie(crazy autocad witch since release  ) 🙂
niteshparajuli
Thanks Emilio 🙂
