Hi Everyone,
I had a crash while creating a hatch. I recovered the drawing file and the "Hatch Creation" ribbon is stuck on. Clicking the "Close Hatch Creation" button repeats the last input command almost like hitting the enter key.
I have tried the following to fix the problem:
1. Recover Drawing
2. Delete hatch object that caused the crash
3. Purge & Audit
4. DXF Out, Purge & Audit DXF
5. Changing workspaces
6. Closing & reopening the ribbon
7. Saving the file as a different name & opening
Nothing has solved this issue. Any suggestions?
Eddie
Hi Everyone,
1. Recover Drawing
3. Purge & Audit
Eddie
Hi @Anonymous,
Is this problem happening only with the one file? Does it also have any attachments/xrefs? Is it possible to share the file(s) with me? If the file needs to be private, please send to me at john.vellek@autodesk.com and include a link to this thread in your email.
Hi @Anonymous,
Hi @Anonymous,
Were you able to get this working? I haven't seen you come back to the thread. If you still need help with the file, please attach it to a post so I can take a look.
Hi @Anonymous,
I should mark this as completed. I did eventually figure it out. As silly as it is, I just created another hatch object and then it closed it out on the ribbon. Sometimes the solution to a problem is the simplest thing that you don't think of right away, I suppose.
For some reason when I try to add a hatch my hatch command will not stop... I tried creating another object hatch no luck... this is really frustrating.
Have you tried turning your hardware acceleration off?
Yes // no luck still stuck in the twilight zone
If I remember correctly, I entered the hatch command in the prompt and then selected an object to hatch. It then fixed itself.
