AutoCAD Forum
Hangs
13 REPLIES 13
Message 1 of 14
589 Views, 13 Replies
Hangs
How do I stop 2015 hanging while it saves?  Just replced Graphics card with a AMD V4900 and it still does it.
Hangs
13 REPLIES 13
Message 2 of 14
braudpat
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
1) Have you opened your DWG in RECOVER Mode, PURGE (if possible) ReSave it, Quit, ReOpen to test ...
2) Have you installed the SP 2 (or at minimum the SP 1) on your ACAD 2015 ?
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-autocad-2015...
3) Have you installed the latest ATI driver for your AMD V4900 ?
4) Which Windows exactly : Win Seven , Win 8.0 , Win 8.1 ?
And 32 or 64 bits ??
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Hello
Patrice BRAUD
Message 3 of 14
rkmcswain
rkmcswain
Are you saving to a local hard drive, local removable drive, a network location, or to A360?
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 14
in reply to: braudpat
It is not just one drawing but any drawing!
Yes, we have installed the latest driver.
Windows 7 64 bit
Simon Ray
Castle Postform Products Ltd
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Windows 7 64 bit
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Message 5 of 14
in reply to: rkmcswain
Network location
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Network location
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Message 6 of 14
rkmcswain
rkmcswain
simon wrote:
Network location
Does it hang if you save to your local hard drive?
If so, then unplug the network cable and test it again (saving to the local hard drive)
simon wrote:
Network location
Message 7 of 14
Yes. It also hangs sometimes when change from a different layout.
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Message 8 of 14
RockyBrown4134
RockyBrown4134
Are you running anything else that would use up resources, like music player, anything streaming from the web, such as weather alerts? Had a user once to complain about his machine was slow. Turns out he was listening to music with a MP3 player. Turn that off and his problem went away.
Might not be in this case, but simple things get overlooked.
Hope this helps.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Hope this helps.
Rocky Brown
Message 9 of 14
in reply to: RockyBrown4134
NO none of these are running
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Message 10 of 14
Our two Expert Elites have already addressed the most important solutions.
Here are 2 entries in my AutoCAD Note file:
AutoCAD: SAVES REALLY SLOWLY: 2012.03.27.TE:
Go to Tools / Options / Open and Save / Thumbnail Preview Settings.
In the "Sheets and Views" panel, if the "Generate Sheet, Sheet View and Model View Thumbnails" is checked, adjust the slider to the middle position.
From Mark at DC:CADD: Austin, Texas: 2012.03.27.TE, around 11:am
Just an idea :
Open ALL yours XREFs
SCALELISTEDIT Command and erase/kill ALL Annotation Scales you can !
Resave your DWG.
Reload your Main DWG, is it faster ?
From AutoCAD Discussion Groups: R2011: braudpatX: 12:24am in “Xref reloading problem” by: nils126: j01-22—2013, 3:29pm
Just an idea :
Resave your DWG.
Message 11 of 14
Unfortunately hasn`t helped!
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Simon Ray
Rye Harbour Road
Rye
East Sussex
TN31 7TE
Tel; 01797 224074
Fax; 01797 226830
Message 12 of 14
braudpat
braudpat
Hello
Q1) Is it possible to share with us your DWG + XREF DWGs ?
Q2) Have you tried to run with Anti-Virus DISABLED ?
Patrice BRAUD
Hello
Patrice BRAUD
Message 13 of 14
Victoria.Studley
Victoria.Studley
Hi Simon,
Does your machine use dual graphics cards (Intel and AMD)? If so, take a look at this article that explains a known graphics issue for machines that use dual graphics cards, and apply the solution.
You could also try deleting the contents of your %TEMP% folder, which can cause the behavior you've described if it gets too full.
Additionally, if the drawings you're working with contain a lot of hatches, you might try converting the hatches and retesting the performance.
Finally, here is a list of suggestions for optimizing performance in the Windows 7 environment.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Hi Simon,
Victoria Studley
Message 14 of 14
doni49
doni49
You say "it hangs".  How long do you wait before you declare that to be the case?  I once had a user complain that acad would hang -- but then when I observed his process, he was just being impatient.  I sat down at his pc and took control.  I opened the same file, did the same sequence of commands that he had just done.  Then I saved the file.  After a few seconds, he said "see it does it for you too" and reached for the keyboard.  I pushed his hands away and told him to wait and shortly after that, the command line returned to normal and the save was finished.
Also...   You said it does this for all files.  If these files are all based on the same template, they could all be affected by the same issue.  They could all be the same or similar size too.
Try opening the attached file, draw a line and then save the file.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Don Ireland
AutoCAD Inside the Factory
